Dune5k
#1 Posted : Monday, September 15, 2008 6:57:13 AM(UTC)
Dune5k
Gas dryer heats up initially when set on each of the three available temp settings then does not get hot again regardless of cycle selection. Air flow is good and ducts are clean. I have printed out the diagrams and parts listings. After reading existing posts, it seems it might be a coil problem. The drawings and parts lists don't show coils separate from the gas valve assembly. Are they available separately? Is there something else I should check first? Any suggestions would be appreciated! Thanks!!
fixtec90
#2 Posted : Monday, September 15, 2008 7:54:28 AM(UTC)
fixtec90
Your gas solenoids (coils) are most likely your problem. They are available separately. There are two, a primary and secondary coil, replace both.
Dune5k
#3 Posted : Monday, September 15, 2008 8:00:46 AM(UTC)
Dune5k
Thanks for the response. Any idea what the part number would be?
fixtec90
#4 Posted : Monday, September 15, 2008 8:45:30 AM(UTC)
fixtec90
12001349 this is it.
#5 Posted : Monday, September 15, 2008 3:02:29 PM(UTC)
You also can find it here: AP2150379 and you can have them next day.
Dune5k
#6 Posted : Friday, September 19, 2008 11:24:16 AM(UTC)
Dune5k
Replaced the gas solenoids and it works fine again. Thanks for the help!!!!
#7 Posted : Friday, September 19, 2008 5:28:28 PM(UTC)
We're glad you were able to fix it.
Guest (7)
