delores
#1 Posted : Friday, January 28, 2011 3:07:58 PM(UTC)
delores
Washer will not spin, I hear the motor running:confused:
#2 Posted : Friday, January 28, 2011 5:00:02 PM(UTC)
Remove the washer cabinet and check the motor coupling. The instructions are attached to the reply.
- The motor coupling Part number: AP3963893
File Attachment(s):
How to remove the washer cabinet.doc (21kb) downloaded 16 time(s).
How to remove the pump.doc (25kb) downloaded 9 time(s).
How to replace the motor drive coupling.doc (25kb) downloaded 18 time(s).
Kenmore washer 80 series spin problem (Washer Repair)
by Ikisntel 5/18/2015 10:50:24 AM(UTC)
by Ikisntel 5/17/2015 11:49:40 PM(UTC)
kenmore washer 80 series (Washer Repair)
by Grover327 5/22/2011 6:17:51 PM(UTC)
Kenmore washer 80 series leak then ... (Washer Repair)
by twangme7 7/6/2010 12:04:30 PM(UTC)
by charmers 6/25/2008 5:52:50 AM(UTC)
