2 Pages12>
bgrable
#1 Posted : Thursday, January 27, 2011 12:31:02 PM(UTC)
bgrable
The washer works in Spin cycle. However at start up no water is comming in.
I checked the hoses and the screens everything is very clean. This new machine has an auto fill . Is that my problem?
#2 Posted : Thursday, January 27, 2011 1:27:40 PM(UTC)
Remove the washer cabinet.
[youtube]OlAFQnkapLM&rel=1[/youtube]
Check for 120 VAC to the water inlet valve solenoids while the washer in the fill mode and the water temperature switch is in different positions. Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG MVWC6ESWW0 AUTOMATIC WASHER | AppliancePartsPros.com
File Attachment(s):
How to remove the washer cabinet.doc (21kb) downloaded 15 time(s).
bgrable
#3 Posted : Friday, January 28, 2011 11:29:52 AM(UTC)
bgrable
Gene ,I checked with a volt meter no power to cold or hot . No change in power when I change temperature control.
#4 Posted : Friday, January 28, 2011 4:01:01 PM(UTC)
Check for continuity the thermistor (at the end of the water inlet valve). If it is open or shorted, replace the water inlet valve.
- The water inlet valve Part number: W10175893
bgrable
#5 Posted : Saturday, January 29, 2011 9:55:11 AM(UTC)
bgrable
:confused:
What is a thermistor ? like a resistor, I found two single wires under the hot and cold valves. I removed the two single wires use volt meter and it checks open is that the thermistor? Can the thermistor be replaced by its self? Or the whole valve?
#6 Posted : Saturday, January 29, 2011 3:37:53 PM(UTC)
According to Wikipedia "a thermistor is a type of resistor whose resistance varies significantly (more than in standard resistors) with temperature".
The thermistor is located at the end of the water valve nozzle. It can be recognized by the two wire terminals.
If your voltmeter was set to measure resistance and it shown that the thermistor is open, replace the water valve. The thermistor comes as a part of the water valve only.
bgrable
#7 Posted : Sunday, January 30, 2011 5:25:42 AM(UTC)
bgrable
The volt meter says its open so I will order the part and replace it.
Thanks Gene:)
#8 Posted : Sunday, January 30, 2011 1:44:40 PM(UTC)
bgrable
#9 Posted : Tuesday, February 1, 2011 4:15:16 PM(UTC)
bgrable
To Gene, I replaced the inlet valve with the thermistor. I here the machine now agitating but no water is comming into the machine. This machine has a auto fill level do I need clothes in the machine.:confused:
#10 Posted : Wednesday, February 2, 2011 4:50:32 PM(UTC)
Remove the washer cabinet and trace the pressure hose (#21 on the diagram) from the outer tub to wherever it is connected inside the control panel. Post the result.
Visually inspect the electronic control attached to the back of the timer for any cold solder joint or burned spots.
I also attached the electric schematic for the washer.
File Attachment(s):
MVWC6ESWW0.pdf (302kb) downloaded 41 time(s).
Guest (4)
2 Pages12>
