There is a really bad sound coming from the freezer sounds like a fan freezing up is there a way to diagnose the problem where do I look...
A model number may help others help you. Model Number LocatorFirst thing to do is remove the evaporator cover from inside the freezer so you can see and check the evaporator fan. |
THIS FORUM IS DEAD!!!!!!! |
