gilkelley
#1 Posted : Wednesday, January 26, 2011 4:14:16 PM(UTC)
gilkelley
Purchased this unit used and immediately found the motor coupler needed replacing. Now everything seems to operate ...except for one thing...when I wash clothes using the NORMAL cycle the clothes seem to be much wetter when I put them into the dryer. I have checked to see if there is any real difference in the others cycles vs the NORMAL cycle and see no difference..any ideas?
Joe / APP Team
#2 Posted : Thursday, January 27, 2011 2:06:28 PM(UTC)
Joe / APP Team
Gill,
Does it drain a full tub of water in 90 seconds or less ?
If not, suspect a weak,damaged drain pump or kinked,clogged drain hose.
If the drain time is in range, suspect a slipping clutch assembly,
Part number: AP3094537
and, or spin tube assembly,
Part number: AP3094539
(one or the other)
here's some info to help you out,
http://forum.appliancepartspros...-washer-brake-shoes.html
Whirlpool washer wet clothes (Washer Repair)
by bobhickory 5/1/2020 9:48:31 AM(UTC)
wet clothes after spin (Washer Repair)
by ewade1601 8/24/2015 7:52:53 AM(UTC)
KENMORE 80 series wet clothes after spin cycle (Washer Repair)
by APPLIANCEDUDE1972 4/22/2015 4:05:46 PM(UTC)
Wet Clothes After Spin (Washer Repair)
by ZipAgent 4/21/2014 1:04:34 PM(UTC)
Wet Clothes (Washer Repair)
by Baldrick 3/25/2014 8:34:12 AM(UTC)
Maytag Atlantis wet clothes after spin (Washer Repair)
by Dkinyon 4/8/2013 10:05:33 AM(UTC)
Wet Clothes - End Of Cycle (Washer Repair)
by bigblanar 2/13/2013 11:20:43 AM(UTC)
GE Dryer Squeaks with wet clothes (Dryer Repair)
by boomerman58 1/14/2013 12:48:06 PM(UTC)
by ljs.52 1/13/2013 10:40:58 AM(UTC)
Whirlpool Duet Sport won't spin at high speeds... wet clothes (Washer Repair)
by Yellowtruck79 6/10/2012 7:31:44 PM(UTC)
wet clothes occasionally (Washer Repair)
by Timdezego 2/6/2012 3:24:02 PM(UTC)
wet clothes after final cycle (Washer Repair)
by BobBHo 12/13/2011 1:30:06 PM(UTC)
Washer will spin, but only when some of the wet clothes are removed (Washer Repair)
by yendor64 11/9/2011 12:35:29 PM(UTC)
wet clothes after finish cycle. (Washer Repair)
by carlos r 8/16/2011 4:27:56 AM(UTC)
by doitmayself 8/15/2011 11:31:09 AM(UTC)
