HappyPappy
#1 Posted : Friday, September 12, 2008 6:49:02 PM(UTC)
HappyPappy
Our washing machine is showing an Lr code and will not spin out. I noticed there is a service bulletin to check for loose wires. Which cover do I take off to check for loose wires and is there any trick to getting the covers off. Once I get to cover off I'll have more questions.
HappyPappy
libertyappl
#2 Posted : Friday, September 12, 2008 8:13:14 PM(UTC)
libertyappl
Happy,
If you look at the breakdowns of your machine it will help you remove the panels. You're probably going to start in the control panel, then remove the top panel and the front panel.
Hope this helps
Nat
Model MAH5500BWW
