ritaser
#1 Posted : Friday, September 12, 2008 12:43:23 PM(UTC)
ritaser
The panel buttons no longer worker. What part do I need to order and is it something I can do myself?
Rita
#2 Posted : Friday, September 12, 2008 3:17:33 PM(UTC)
Hi Rita,
Most likely the problem is a broken tabs on the control module front cover. This is pretty common problem and the job is not too difficult to DIY.
You have to remove the outer door panel and the fascia panel. You can find the complete instructions in one of our previous posts: http://forum.appliancepartspros...86-bosch-dishwasher.html
- The part number for the front cover is AP2802872
Here are the break down diagrams for the Bosch dishwasher Model SHU5315 UC/06 (FD 7705-7912)
ritaser
#3 Posted : Friday, September 26, 2008 4:09:33 PM(UTC)
ritaser
HI Gene,
We replaced the control module as you suggested. That definitely fixed the buttons. But I just ran the dishwasher and the timer is not advancing. If it reads 75 minutes it just keeps running and the number does not change. And the dishwasher stays in the wash cycle.
What should I consider next?
Thanks, Rita
ritaser
#4 Posted : Tuesday, September 30, 2008 7:07:46 AM(UTC)
ritaser
Hi Gene,
We replaced the part you mentioned. The buttons now work, however we ran the dishwasher and it is not cycling down. Example the timer states 79 minute and the diswasher is running but the time does not change so it stays at the same time. Is it a reset problem or another part.
Please let me know.
Thanks, Rita
The model # again was SHU5315 uc/u06 FD7710
#5 Posted : Tuesday, September 30, 2008 4:12:35 PM(UTC)
Hi Rita,
Possible there is a problem with the heating circuit. You can use the troubleshooting guide from one of our previous posts: http://forum.appliancepartspros...troubleshoot-manual.html
jeturner38
#6 Posted : Thursday, November 13, 2008 10:53:33 AM(UTC)
jeturner38
Gene,
Thank you for your quick response. Now the question is where do I find out how to get to this part to repair it?
TIA,
#7 Posted : Thursday, November 13, 2008 11:15:14 AM(UTC)
Please click on the link above and read the manual.
ayou
#8 Posted : Wednesday, November 19, 2008 7:11:26 AM(UTC)
ayou
I have a Thermador dishwasher DWHD64CP/22, which I know is made by Bosch (although I don't know what is the Bosch model equivalent). It is about 3 years old and it stopped draining a few days ago. I've tried to use the manual drain feature but still no luck. I can hear some clicking (I think it's the solenoid opening) but the the pump does not come on. I removed the 5 hex screws at the bottom inside the tub and found a lot of crud deposited around the basin (which would explain why the dishwasher hasn't been cleaning well). Does anyone know if the drain pump is the problem? What about the soft gunk build up? Has anyone experienced this before?
jeturner38
#9 Posted : Thursday, November 20, 2008 7:38:23 PM(UTC)
jeturner38
Originally Posted by: jeturner38 Go to Quoted Post
Gene,
TIA,
Just a note to your repair advice on this dishwasher -Bosch SHU5315/UC12
My husband repaired it and discovered that you do not need to remove the door of the dishwasher. All that needs to be removed is the top panel where the buttons are. This may help the next person having to replace the control module.
blacktailwally
#10 Posted : Saturday, August 11, 2012 5:33:04 PM(UTC)
blacktailwally
Rita
Rita, I am having the same problem. panel buttons push in but the plastic part behind the button (control module front cover) has broken. i took off the front cover and panel to discover this. I went to ************************.com to order that front cover for 42 dollars. I have a bosch shu4302 model dishwasher. hope this helps you. Linda
Guest (8)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD 12/7/2023 2:38:23 PM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
Bosch Dishwasher Model SHE3AR56UC/07 (Dishwasher Repair)
by EDK1747 8/30/2023 7:42:58 AM(UTC)
Bosch Dishwasher SHE3AR56UC/07 (Dishwasher Repair)
by Guest 8/27/2023 11:27:21 AM(UTC)
Bosch Dishwasher skips to "clean" even after part replacement (Dishwasher Repair)
by Guest 6/20/2023 5:17:19 PM(UTC)
Bosch dishwasher SHX65T55UC/07 not dispensing soap unless in "Express" mode (Dishwasher Repair)
by callussun 4/19/2023 9:46:00 PM(UTC)
Bosch dishwasher shem3ay 55n/25 (Dishwasher Repair)
by Guest 3/23/2023 5:18:20 AM(UTC)
Bosch dishwasher only drains on reset and specific cycle (Dishwasher Repair)
by vusedad 10/18/2022 8:54:46 AM(UTC)
Bosch dishwasher model SMV41D10EU/48 Not working (Dishwasher Repair)
by adriandlb 10/7/2022 12:18:47 AM(UTC)
Bosch Dishwasher SHX68T55UC/02 Leak Identified: How to Fix? (Dishwasher Repair)
by jonneytaee 8/31/2022 4:48:51 AM(UTC)
Bosch Dishwasher Model SHPM65Z56N (Dishwasher Repair)
by Guest 7/8/2022 9:00:03 AM(UTC)
