Upper Spray arm has a rubber gasket that seals against back wall to water supply. Is it possible to just change the gasket or do I have to replace the spray arm ? If I do replace the spray arm, I cant figure out how to get the old one off. Any help ?
THIS FORUM IS DEAD!!!!!!! |
