OVEN READ F1 AND WOULD CONTINUALLY BEEP, REPLACED CLOCK /TIMER ON ADVICE OF REPAIR MAN PART#AP3211342 SEEMED EASY ENOUGH. AFTER CHANGING CLOCK/TIMER PLUGGED STOVE IN AND TIMER READ,PF WITH BLINKING CLOCK. I WAS CAUGHT OFF GUARD WHEN CLOCK/TIMER DID'NT COME WITH THE OVERLAY. I SINCE ORDERED OVERLAY PART#AP2126682. TRIED RIPPING OLD OVERLAY OFF OLD TIMER/CLOCK AND ATTACHING BUT NO LUCK...:confused:
The PF code is power failure.
:) thanks, overlay solved my problem. life is good:)
