How does this work? Do I post my question and wait or does an answer arrive by E-Mail. Will wait for an answer.
Rank: Administration
Well, the answer would be posted here and you will be notified of that via email. What's the question? :)
One of my bloodhounds liked the way the knobs on my very old stove smelled bit it off the stove and chewed it into an unrecognizable ball. I am not able to read the entire model number but it ends in W520R. I can't find the part but can give a very good description. IT IS 2 & 1/16" in diameter and made of aluminum-- there is a black plastic finger grip in the center of this knob that continues through to the back. On the front are only two words printed in black "OFF & HIGH" Turning it over there is no metal insert in the rear "D" hole. At it's widest part the D hole is 5/16". The shaft to slide it on the stove in the rear is 3/16" long HELP
