This freezer runs but does not cool. i have changed thermostat,and evaporator fan. compressor does run as well. please help
You have been a member since:: 8/13/2008(UTC) Posts: 3,097
Please give a complete description of how & when the freezer started not cooling. Nat
If the comp. runs and the fan is running, There is no gas in the system!!! You need a PRO to check for a leak in the "sealed system" Should be covered if under 5 yrs old!!!!
Is the compressor warm to the touch?
