I have replaced the right front dual eliment switch but the element will not turn on and the hot surface light is stilll on all the time. I took the glass top off and removed the sensor. Then I went to you parts diagram to found out I cannot get the sensor, but must buy the whole dual element with sensor = for ~$98. Any other suggestions or options?
GregP
Originally Posted by: kayakcrzy  Thanks Tom. I thouoght that would be the case. The only question left is: ....... Is there any thing other than the switch (which I have replaced) or eliment w/sensor that could be the problem? GregP
