I have a GE Nautilus portable dishwasher that has been working perfectly until the other day when the knob broke. I'm trying to find a source to order a new one, but can't match up the model number (GSC3304F01WW) to any site or database I can find. They all go from 32xx to 34xx.
Any suggestions would be appreciated.
I also cannot find any info on the given model number but it looks like the 3200 and 3400 series use the same knob so perhaps the 3304 also uses it. If yours looks the same then odds are high that the below will do the job. Part number: AP2038967
Click on the picture for more info. Note: It is also available in white and it is much cheaper for some reason. |
THIS FORUM IS DEAD!!!!!!! |
I had considered that, however the knob on our dishwasher is not quite the same shape - specifically, the out-facing part that points to the cycle is tapered from end to end, thus slightly changing the shape of the inner connecting part. It MIGHT work, with this one, but I'm not confident. Thanks for your suggestion.
MUCH closer! Thanks very much.
