Diane Gober
#1 Posted : Saturday, January 22, 2011 8:17:48 AM(UTC)
Diane Gober
Was baking and oven made very loud noise. Everything works except the oven and broiler elements don't come on. The electronics seems to be working and lets you act like your are baking and broiling but again nothing heats up. We took the heating element to a parts place and they said it test to be good. any ideas???? Are there any fuses?? We need help like everyone else money is tight. THANKS!!
#2 Posted : Sunday, January 23, 2011 4:55:35 AM(UTC)
Here are your parts. Includes a wiring diagram
Replacement parts for FRIGIDAIRE FEF366ASK Frigidaire/electric Range | AppliancePartsPros.com
There are no fuses in this unit.
Check that the wires from the control panel to the elements are OK.
Be sure to unplug the unit when doing this.
If the wires are good then odds are that your control board is toast.
kayakcrzy
#3 Posted : Sunday, January 23, 2011 6:58:51 AM(UTC)
kayakcrzy
The clock control board part # is 316557104. This is a real easy repair Dianne. Unplug the oven, and take the back off of the control panel, and there should be 4 screws holding it in place. Pull the wires off, and replace. Just make sure, you take one wire off the old on, and put in on the new one. That way you don't get confused. Once you have it wired, then peel of the front plate off the old clock, and then stick it on the new one, and then reinstall. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
