cookininmaxwell
#1 Posted : Saturday, January 22, 2011 9:11:49 AM(UTC)
cookininmaxwell
My older model dishwasher is not draining properly. I no longer have the manual. Can someone please suggest something.
#2 Posted : Sunday, January 23, 2011 2:53:14 AM(UTC)
Here is your parts breakdown.
Replacement parts for MAYTAG DWU7400AAX DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Here is a manual
http://appliancedigest.com/index.php?/files/file/533-16007823-maytag-dishwasher-service-manual/
You will have to join the site to download the manual but it is a good site for appliance manuals.
First I would undo the drain hose at the house plumbing and check it.
This is a common area where junk collects and causes a partial plug.
Check that the house plumbing is OK.
Try draining the unit into a pail. Be sure to hold the drain hose firmly in the pail and put a rag/towel over the pail so it does not splash all over.
If it drains OK it is probably a house plumbing problem.
If it does not drain OK then work your way abck to see if you have a partial plug in the system
Or
You could disassemble the pump and check it first.
