AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Help my kenmore dishwasher has a little lock light on and it wont turn on
there is a little light on my dishwasher that looks like a lock, and its turned on and i cannot turn it on the only thing on is that light . I know there is a way to turn it off i just cant remember please help. thanks:confused:
:D Hold the no heat dry for four seconds and the light should go out. If not you might have the same problem I have. dishwasher
Originally Posted by: dishwasher  :D Hold the no heat dry for four seconds and the light should go out. If not you might have the same problem I have. dishwasher what was the problem with yous because my light wont go off
varcadipone,
If the controls did not unlock after you followed the dishwasher's instructions then the problem is a bad control panel. If you need the right part number post the complete model number of the dishwasher and the color of the control panel.
Dishwasher Repair
