ballet08
#1 Posted : Friday, January 21, 2011 3:25:48 PM(UTC)
ballet08
I have removed the Toekick plate and can see the motor to my right.
It will not move. How do I turn the motor . I can unplug the unit and then restart the unit. What type of a tool should I use the move the motor blade? Roy
#2 Posted : Saturday, January 22, 2011 2:49:01 AM(UTC)
Just use two flat blade screwdrivers to free up the motor, most probably just the pump seal froze up, usually happens if it was not used for a while. Then dump a half gallon of vinegar in it to dissolve calcium and soap residue from the pump.
ballet08
#3 Posted : Saturday, January 22, 2011 6:00:33 AM(UTC)
ballet08
Thanks Richappy.:)
