My washer is not removing the water from the clothes completly. It seems to be draining ok, but my agitator is dot moving at all. Also, when i try turning it on it makes a noise. thank you, rosa:confused:
It makes a steady griding noise.
Check the coupling between the motor & the transmission. It's a 3 piece part, consisting of 2 white parts with 3 tabs and a black rubber part that goes in between them. Nat
