2 Pages12>
mhnsn
#1 Posted : Monday, September 8, 2008 7:04:36 AM(UTC)
mhnsn
everything works except will not agitate. agitator turns freely by hand and wobbles from side to side. if agitator needs replaced how do i remove it? i dont know how to work on a washer
#2 Posted : Monday, September 8, 2008 1:06:56 PM(UTC)
Does the motor run during agitation?
Remove the front panel and check the belt.
Drags1998
#3 Posted : Monday, September 8, 2008 3:41:42 PM(UTC)
Drags1998
The agitator Drive Bell has failed, Get your hands under the agitator and lift it out of the washer,(may require MUSSLE) the white piece in the center of the tub is the part that you neen to replace, The splines on the inside are stripped!!!!
trinidred7
#4 Posted : Wednesday, September 10, 2008 8:00:15 AM(UTC)
trinidred7
hello, hopefully I'm doing this right. My whirlpool washer(agitator)I think thats what they call the center white piece that suppose to spin, bottom part spins, but the top does not. The cloths just sits there on top the water not being pulled down to get washer. I pulled the whole thing out,but not sure if I have to replace the whole white part of just an internal piece. Help me lol..
libertyappl
#5 Posted : Wednesday, September 10, 2008 8:03:46 AM(UTC)
libertyappl
trin,
your need to replace your agitator dogs. Cheap fix!! Whirlpool part number 80040.
Nat
trinidred7
#6 Posted : Wednesday, September 10, 2008 12:13:37 PM(UTC)
trinidred7
Agitator dogs. Is that the piece inside to agitator with the teeth.?? About how much does that part run? Thanks for your help libert.
libertyappl
#7 Posted : Wednesday, September 10, 2008 1:59:06 PM(UTC)
libertyappl
those are the teeth looking things and they are less than $10
Nat
Drags1998
#8 Posted : Wednesday, September 10, 2008 2:17:35 PM(UTC)
Drags1998
How did this post go from a GE washer to a Whirlpool???? Check the Model# on the first post!!!!!!!!!!! Thats a GE M#!!!!!!!
libertyappl
#9 Posted : Wednesday, September 10, 2008 2:51:50 PM(UTC)
libertyappl
Yes it is and someone else with a Whirlpool had a simular problem. No big deal.
#10 Posted : Thursday, September 11, 2008 12:43:25 PM(UTC)
trinidred7,
In order to provide most accurate advise we ALWAYS need the complete model number of the unit.
110.24622300 direct drive washer wont agitate or spin motor hums (Washer Repair)
by Guest 10/10/2021 7:32:00 PM(UTC)
Whirlpool washer tub wont agitate or spin (Washer Repair)
by beachvillagers 4/6/2017 10:36:51 PM(UTC)
Washing Machine Wont Agitate Or Spin (Washer Repair)
by SCOTT1946 1/23/2017 12:31:34 PM(UTC)
fills but wont agitate or spin or drain (Washer Repair)
by johnny wen 6/15/2016 7:06:07 AM(UTC)
wont agitate (Washer Repair)
by tamijo77@gmail.com 5/16/2016 5:13:03 PM(UTC)
washer wont agitate or spin (Dishwasher Repair)
by steve2016 4/21/2016 8:12:47 AM(UTC)
Whirlpool wont agitate will drain and low speed spin (Washer Repair)
by mark6200 1/30/2016 2:31:58 AM(UTC)
washer wont agitate (Washer Repair)
by jgraves1 1/23/2016 12:26:39 PM(UTC)
Maytag Washer Wont Agitate When Clothes Is Addded (Washer Repair)
by dyedra 10/13/2015 12:40:16 PM(UTC)
GE washer fills wont agitate, drains but wont spin (Washer Repair)
by DUB C 6/23/2015 7:43:40 PM(UTC)
Frigidaire top loader wont agitate, will spin. (Washer Repair)
by BobK74 5/9/2015 9:01:58 AM(UTC)
Whirlpool washer wont agitate (Washer Repair)
by SPOONMAN1 3/16/2015 6:02:53 AM(UTC)
my washer wont agitate or spin ULTIMATE CARE ll (Washer Repair)
by ballprez6 12/26/2014 11:12:12 AM(UTC)
by ryan1976 12/1/2014 4:23:04 AM(UTC)
GE Profile washer wont agitate or spin, motor will hum (Washer Repair)
by copperman 8/12/2014 4:20:30 PM(UTC)
2 Pages12>
