Runninglights
#1 Posted : Wednesday, September 10, 2008 11:49:43 AM(UTC)
Runninglights
So I was drying a load and it just stopped mid cycle. I've checked the service panel breaker, door swith continuity, heat level selector continuity, and several other items like that. Can anyone help?
libertyappl
#2 Posted : Wednesday, September 10, 2008 11:55:25 AM(UTC)
libertyappl
Test the thermal fuse.
Nat
Runninglights
#3 Posted : Wednesday, September 10, 2008 12:01:31 PM(UTC)
Runninglights
Can you tell me where it is?
libertyappl
#4 Posted : Wednesday, September 10, 2008 1:52:56 PM(UTC)
libertyappl
Remove the back panel and you will see where the wires attach to the thermostats. remove each pair of wires at a time and test the thermostat with an ohm meter(for continuity).
Nat
Guest (4)
