calgal
#1 Posted : Tuesday, October 2, 2007 6:59:13 AM(UTC)
calgal
My kitchenaid washer will not spin. I assume I had an uneven load yesterday. When I got home the washer had moved sideways. The rug inside was still soaking wet. When I run the spin cycle I can hear water being sucked out of the machine, but the tub does not spin. Under the washer I can see rubber shavings. I have removed the back panel, but I can't seem to but my finger on what is wrong. Can any one help me and tell me which part I need to replace?
Thanks for your assistance:)
calgal
#2 Posted : Tuesday, October 2, 2007 5:07:32 PM(UTC)
calgal
I was able to do more research and determined that the motor coupler was shot and needed to be replaced. Found the part and replaced today. I am running a cycle right now to see if it works properly. Currently in the rinse cycle so it did spin at least once. Think I have it fixed. Wasn't to hard to do either for this California gal! The part was $15.95 at my local parts store.
