Washer Won't Go Through Cycles
Here is a repair guide for the agitator dogs, but yours does look different then what I have seen before.
http://appliancejunk.com/forums/index.php?topic=105.0
I wonder if it was taken apart before and maybe not put back together the correct way?
If you remove the washer cabinet you and run the washer you should be able to locate the leak.
