Washer Won't Go Through Cycles
Washer: Kenmore Elite Series
Model: 110.20952992
The timer part I bought from Appliance parts pros came today and I installed in fine and the machine now goes through the cycles like it’s supposed to. But I’m left with two additional problems:
  1. the long skinny top part of the agitator does not really spin that forcefully so i went out and bought dog ears to replace and cannot access that area to replace the parts. It turns but when it’s filled with clothes it doesn’t look like it’s moving much but when you put your hand in the machine and feel low to the bottom that bottom agitator part is moving very fast and forcefully like it’s supposed to. a) I popped off the cap where the fabric softner goes and then grasped the white cap under that and took that out. Then I see what looks like a square type bolt with a round center. I don’t seem to have anything that can fit that…I need something square to loosen it? I bought the dog ears (APP didn’t have them yesterday) and I’m having problems getting to them in order to replace them. Help!!!
  2. There is a leak only on the right side of the washing machine. The left side in bone dry but the right side, even from underneath is beginning to look rusty. What do you think this could be? Because the outside of my washer is all connected, how would I check? Tilt and rest the machine against the wall and look underneath?
Thanks for your expertise…I await your response.
