I just replaced the control board on my Frigidaire dishwasher because it was not completing any of the wash cycles. Now with the new board installed I have an issue with the sanitize option button not responding, the light does not come on when I press the sanitize option button, it does not run a sanitize cycle at all. What will fix this problem? I have not seen any posts on this particular problem or model for that matter. HELP!
Open the control panel and inspect the connection between the switch and the control board. If there is nothing wrong, you may want to replace the switch assembly. - The switch assembly Part number: AP3867097
Originally Posted by: emismommy2008 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I just replaced the control board on my Frigidaire dishwasher because it was not completing any of the wash cycles. Now with the new board installed I have an issue with the sanitize option button not responding, the light does not come on when I press the sanitize option button, it does not run a sanitize cycle at all. What will fix this problem? I have not seen any posts on this particular problem or model for that matter. HELP! My sanitize button won' t work when I press power plus or normal wash. When I press the sanitize button the light doesn't come on and it doesn't sanitize. What could be the porblem? It's not even a year old.
Why does 't my sanitize button don't work? My dishwasher isn't even a year old. I use power plus or normal load and I want it to sanitize the load.
Originally Posted by: LMCCORD ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My sanitize button won' t work when I press power plus or normal wash. When I press the sanitize button the light doesn't come on and it doesn't sanitize. What could be the problem? It's not even a year old. I like to use the sanitize button. That is why I picked my Frigidaire Gallery dishwasher. What do I have to do to repair this problem? LMCCORD :( :(
