terrence l. thomas
#1 Posted : Wednesday, January 19, 2011 11:29:12 AM(UTC)
terrence l. thomas
gas FP not lighting. has elec ignition. investigation found insulation burned off right below ceramic ignitor, so spark was arcing between wire & thermocouple. i pulled ign. wire away from th-cpl. and spark is lighting pilot every time now. ? is there some type of heat resistant i
insulation i can put around wire to prevent arcing?
Have reinsulated ign. wire, now get spark every time when tested but no spark when attempting to light pilot.
icehouse
#2 Posted : Saturday, January 22, 2011 7:29:11 AM(UTC)
icehouse
Though I have not worked on gas fireplaces I did find this pdf which seems to cover your problem.
http://www.ultramodern.com/Bulletins/BUL-1000.pdf
