2 Pages<12
#11 Posted : Tuesday, January 18, 2011 12:41:44 PM(UTC)
Well you have stumped me, I cannot think of anything else.
It would be very, very rare that 2 circuit boards would have the exact same fault.
I am going to put this into the tech section may be I missed something or someone else has run into this and knows the fix.
fapel
#12 Posted : Tuesday, January 18, 2011 4:49:23 PM(UTC)
fapel
OK, put the new control board back in and now it is working!!! :D The only thing I can figure is that I had a loose wire or something didn't go back correctly the first time I tried it.
Again, thank you SO MUCH for the time you took to help me!
#13 Posted : Wednesday, January 19, 2011 12:20:26 AM(UTC)
You are welcome
This one was a bit of a hair puller for a while.
I am very happy to see that your perseverance was rewarded with success.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
2 Pages<12
