resurface
#1 Posted : Tuesday, January 18, 2011 11:08:18 AM(UTC)
resurface
Water remains in the basin. Checked for cloggs and none found. Drain line clear. I want to replace the pump but I cannot find a service manual. It appears that the pump is located underneath the dishwasher.
Anyone have a service manual?
Thanks.... resurface.
#2 Posted : Tuesday, January 18, 2011 12:57:51 PM(UTC)
The drain pump is accessible from the front of the dishwasher. The instructions are attached to the reply.
- The drain pump assembly Part number: AP2802249
Here are the breakdown diagrams and Replacement parts for Bosch SMU4056 UC/14 (FD 7402-7902) | AppliancePartsPros.com
File Attachment(s):
Drain pump removal.doc (630kb) downloaded 18 time(s).
Maytag Neptune still not draining fully after drain pump replacement (Washer Repair)
by wrboozer 8/3/2014 7:59:42 AM(UTC)
dishwasher drain pump replacement (Dishwasher Repair)
by tcat1100 2/26/2009 5:30:57 PM(UTC)
Bosch drain pump replacement (Dishwasher Repair)
by Tom4852 9/18/2007 6:49:38 AM(UTC)
