Journey10
#1 Posted : Monday, January 17, 2011 11:06:15 AM(UTC)
Journey10
Top burners on range turn on and work fine. When I turn pre-heat, Bake Broil it does not turn on. Display works fine, it just does not trun on. Any idea of cause? Could it be the AP2150412 part (Igniter kit) you previously recommended to another post?
Joe / APP Team
#2 Posted : Tuesday, January 18, 2011 11:13:21 AM(UTC)
Joe / APP Team
Journey,
Yes,
The igniter assembly, is the weakest link in the system, and is usually 95%
of the no ignition, or slow to heat, not cooking proper, complaints on a gas range.
If you have a multi meter, you can check for 120 VAC to the igniter in a bake cycle, on the wires that connect to the igniter, from the ERC/Clock.
That would varify if the ERC and wiring are working correctly.
Part number: AP2150412
Good Luck,
