this model microwave sounds like everthig is working but it doesnt heat. you can i believe hear the magnitron "grunting" but it doesnt heat the water jerry thanks
A low, growling noise usually indicates a bad High-voltage transformer. If you have a meter and are comfortable making live circuit tests, you can confirm this by first seeing if you are getting 120VAC to the transformer.
