Originally Posted by: roger tate
Ok i checked the motor coupler and clutch it looks good. How do i get the agitator off so i can check the drive block. Does it take a special tool to take the agitaor out, and once i get it off what from there? Also could the transmission be bad making this noise? Also when you spin the agitator by hand it makes a clicking noise. Thanks for the help!
Roger,
No special tools are required to remove the agitator, other than a 7/16" socket and 8 to 10 inch extension for your ratchet wrench.
Remove the agitator cap, or softner dispenser.
on the inside you'll see a plastic cover, with finger tabs and a rubber "O" ring type seal, remove the plastic cover.
You'll see the agitator bolt when you look down the center hole in the agitator, remove the bolt(counterclockwise to loosen).
You can remove the agitator as a single piece, by grasping the bottom and lifting straight up.
You should be able to look at the spin block and determine if it's damaged,
If you wish, you can loosen or remove the spin tub locking nut, you could use a small pipe wrench and hammer if needed to loosen.
To remove the spin tub
Remove the white plastic tub cover, by releasing the tabs from the clips on the outer tub(press down on the tub cover above the area where the clips are located and pull out on the tab).
With the nut removed, you should be able to "rock" the tub and break the grip between the spin tub and drive block, and lift the tub out.
With a large flat blade screwdriver, insert the blade into the gap in the block and carefully pry the gap wider, so you can remove the block.
You can then see the spin tube, on the top. where the block was you'll see two tabs on the tube, make sure they're , not rounded off, or distorted,
Look at the bottom of the spin block and check for the same.
Yes, there could be a problem in the transmission, but , that's our last resort.
We're almost done,Based on your post, I'm thinking you're going to find the problem here.
