rosen123
#1 Posted : Tuesday, September 9, 2008 11:19:37 AM(UTC)
rosen123
this is my second frige in the garage. the compressor seems to be working, the coils are clean, but both the frige and the freezer (side by side) have frozen foods in the bottom drawers and in the doors, but the top shelves are ~ 15-20 degrees cooler on both sides. :confused: could it be, simply that it is too hot in the uninsulated garage and the machine cant keep up?
thank you
libertyappl
#2 Posted : Tuesday, September 9, 2008 11:45:18 AM(UTC)
libertyappl
Check the fan in the freezer make sure it is working and the air flow is not blocked. I will try to look up your model and get a beter idea of whats going on.
Nat
