There is no spark for the ignition for any of the top burners. It will not work for any of the burner switches. The spark module has 120 vac when any of the burner switches is on but no HV output. There is no continunity across the 120 volt terminals.
I can't find the part listed in the online parts book.
Can you supply the part number? The cost? Delivery time?
Thank you.
Dale Driscol
The model number posted doesn't pull up, please verify the number and repost. Nat
The Whirlpool Model is SF395LEEQ. Thanks. Dale Driscol
Each burner on your model has a ignitor switch/spark part # AP3095784 or get the ignitor switch and harness complete part # AP3095786 (I would go this route) Cost from here is 52.69 + S/H, but not in stock so may take a few days to get. Hope that helps Nat
