pafnucy
#1 Posted : Sunday, January 16, 2011 4:35:39 PM(UTC)
pafnucy
I removed a door from a Kitchenaid gas range KGRS807SSS00 to tighten a loose door handle and I am stuck; I cannot reinstall the door!
I tried to follow the instructions I found on the web, they worked fine to remove the door but those steps don't seem to work for me:
"To install the door back on the oven, grasp the sides of the door and insert the hinge hangers into the hinge slots and then lift the door slightly and push in at the bottom until the hangers are fully installed in the chassis."
I get stuck with hinges about 3/4 in and that's it.
Please Help!
Thanks, Paf
pafnucy
#2 Posted : Sunday, January 16, 2011 5:36:57 PM(UTC)
pafnucy
I figure it out. I downloaded the user manual from kitchenaid website:
http://shared.whirlpoolc...0Guide%20-%209763457.pdf
and was able to reinstall the door by flipping the hinge latch. Somehow I was able to rmove the door with a hinge latch locked.
Guest (4)
