feile
#1 Posted : Friday, January 14, 2011 7:15:45 PM(UTC)
feile
After a cycle there is water up to the heating element. I have taken the drain hose off, replaced the pump since it was making strange noises and changed the impeller. There is no food stuff in the sump connected to the motor. If i run it with the lower arm off, fill it and then cancel it doesn't drain out all the water. There doesn't seem to be a piston and nut assembly. Any advise?:eek:
#2 Posted : Saturday, January 15, 2011 2:00:12 AM(UTC)
Replacement parts for GLD4450N10CS models | AppliancePartsPros.com
Found the above a little confusing as I do not think you can replace the drain pump impeller.
Did you replace the wash pump or the drain pump?
Check that the drain pump is getting power when it should.
Check that the flapper valves (Items 328 in Section 5) are OK.
To eliminate the house plumbing as a cause.
Undo the drain hose at the house plumbing.
Then hold it in a pail and do a drain cycle.
Be sure to hold the hose securely in the pail and put a towel over it so it does not splash all over.
Note: Items often get stuck at the drain hose to house plumbing fitting and end up causing drain problems.
Eduardo 71
#3 Posted : Saturday, January 15, 2011 4:38:20 PM(UTC)
Eduardo 71
HI I have a 10 year old bosh dishwaher model shu5315/U12 and about four months ago replace the entire panel for about $ 550 but now the dw does not drain the water how I can I find out if the pump is falty and how easy or difficutl would be to change the pump since i don want to spend another 200/300 dls.
Eduardo
#4 Posted : Sunday, January 16, 2011 12:45:49 AM(UTC)
Eduardo 71
You would be getter off starting a new thread using ost New Topic on the first page of this forum section.
Since I cannot get any info on Bosch units I do not answer any questions about them.
feile
#5 Posted : Sunday, January 16, 2011 5:53:31 AM(UTC)
feile
I replaced the drain pump (part 325) with the valve flapper and the impeller(part 430) that mounts on the motor. I am not sure how i test if the drain pump is getting power at the right time. I can see the water draining in to my drain during the cycle though. Do i test that with the voltmeter?:mad:
#6 Posted : Sunday, January 16, 2011 7:21:29 AM(UTC)
[COLOR="DarkGreen"]Do i test that with the voltmeter?[/COLOR]
Yes
feile
#7 Posted : Sunday, January 16, 2011 5:25:41 PM(UTC)
feile
After testing with the voltmeter the pump drain is powered on and off several times for a minute or two during several cycles.:(
