First the turntable stopped turning. Then a few days later it started turning again but now makes a loud grinding noise. I removed the bottom flap and see a small flat round motor with a brass shaft. The shaft turns when I push start, and the motor makes a small noise. Is that the problem, or is there another motor for the turntable? Is the turntable replaceable?
