My GE gas dryer will heat for a little bit and then no heat. I replaced the thermostat but that did not take care of the problem. I would love some help!!!!!
Originally Posted by: deadmusk  My GE gas dryer will heat for a little bit and then no heat. I replaced the thermostat but that did not take care of the problem. I would love some help!!!!! Deadmusk, Based on your description, You most likely have a weak coil/solenoid on the gas valve. Part number: AP3094251
Just remember to unplug the power cord and be cautious, you don't want to damage the glow bar igniter. Good Luck, :) :) :)
