My whirlpool dryer drum is not turning, and in the back the heating element smelled like it was burning. I took off the lid and back and it appears that the belt is still in tact. Is it a thin belt around the middle or a thicker one near the back? Both are still in place. What shall I do now? It is about 10 years old
Originally Posted by: madge  My whirlpool dryer drum is not turning, and in the back the heating element smelled like it was burning. I took off the lid and back and it appears that the belt is still in tact. Is it a thin belt around the middle or a thicker one near the back? Both are still in place. What shall I do now? It is about 10 years old Madge, A model number would have been a great help, But, Your vintage of machine, should have a drum drive belt, approximately 1/2 inch wide and slightly off center of the drum. The large black "belt" at the rear of the drum, is most likely the drum seal. As I understand this, you can start the unit, the unit heats, but the drum does not turn/tumble the clothes, correct ? Can you hear the motor running, or if you remove the exhaust vent can you feel the hot air blowing out the tube ? If you open the door or turn the machine off, does it stop heating ? At this point, I think you may have a bad motor switch/motor, but can't be sure without some additional information, Thanks, :) :) :)
