WallyJ
#1 Posted : Friday, January 14, 2011 7:32:42 PM(UTC)
WallyJ
Replaced left front element (DWG REF # 56) GE P/N WB30T10003 (existing coil had a break & burn mark). Also replaced SW INF. Control 6" BRNR (DWG REF # 3). Left front burner still does not work. Red Surface Units Light on back panel & Red Hot Surface Lights(S) on stove top work for all burners. 3 of 4 burners okay. How come the left front will not work?
kayakcrzy
#2 Posted : Saturday, January 15, 2011 3:41:33 AM(UTC)
kayakcrzy
If you put in a new switch and a new element it has to work, unless, you did something wrong. Look at the switch, and then look at the other switches, and be sure a wire did not come off, another switch terminal, that would feed power to that switch. At this point, the only thing it will be is a wire off, or, you wired it wrong. Tom ApplianceEducator.com
WallyJ
#3 Posted : Saturday, January 15, 2011 6:49:19 PM(UTC)
WallyJ
Tom,
Thank you for your response. I checked the wiring. That's not the problem. To test that theory I swapped the 6" burner elements. The problem swapped locations. Now left front works. Right rear does not work. I bought a second element. Same problem. I used the online parts search to identify the part and verified the same p/n w/ our local GE appliance parts representative. Do you have a data base available to you to identify a p/n that will work? There was a discrepancy between 1400 watt and 1500 watt. I have been using GE p/n WB30T10003 (1500W) for GE Model # JBP78G V1BB, Serial # GM215898G, approx. purchase date 1994. Will you help me?
Walter
kayakcrzy
#4 Posted : Sunday, January 16, 2011 5:23:28 AM(UTC)
kayakcrzy
That is the same part # I came up with. The only thing I could think of is you have a bad element. Tom ApplianceEducator.com
WallyJ
#5 Posted : Sunday, January 16, 2011 5:38:53 AM(UTC)
WallyJ
Thank You. Walter
WallyJ
#6 Posted : Friday, January 28, 2011 11:02:55 AM(UTC)
WallyJ
Terminal positions on the thermal switch are changed on the replacement element. Wiring by position will not work. See terminal markings on old and new thermal switch.
