cuttincups
#1 Posted : 14 years ago
cuttincups
I have a whirlpool LSB6200KQ0 washer that will barley agitate and will not spin at all. It will drain and fill. I've read posts only on not spinning and most recommend drive block, motor coupling or belt repair. Does the semi agitation narrow this down?
sidfink43
#2 Posted : 14 years ago
sidfink43
The coupling is the likely problem, check it out. Here is a video if you need some info.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
Whirlpool Washer Spin problems (Washer Repair)
by aloulew 13 years ago
Whirlpool washer spin problems (Washer Repair)
by diytoot 16 years ago
by kimberly600 17 years ago
