dromonk
#1 Posted : Sunday, September 7, 2008 2:48:04 PM(UTC)
dromonk
i have a kenmore 790 and when i turn on the burners it hums loud
#2 Posted : Monday, September 8, 2008 12:34:42 PM(UTC)
What is the complete model number of the unit?
If it is less than a year old then you have to call Sears because it is still under the full manufacturer warranty.
gallivanter
#3 Posted : Tuesday, September 9, 2008 8:28:18 PM(UTC)
gallivanter
Just to let you know we are having the exact same problem. Ours happens whenever the gas output is high, either from a burner or the oven. It is one day old. The repair tech is coming out on Friday.
LarryMac
#4 Posted : Tuesday, September 30, 2008 12:31:10 PM(UTC)
LarryMac
I have a 2005 Kenmore Model 790 that also hums when ever the top burners or the oven is on. It did not do this at first but has started in the last month. There is no gas smell. Is this dangerous?
libertyappl
#5 Posted : Tuesday, September 30, 2008 1:13:45 PM(UTC)
libertyappl
We need all 11 digits of the model number to assist you.
Nat
CA_Homeowner
#6 Posted : Friday, December 19, 2008 11:07:19 PM(UTC)
CA_Homeowner
I'm having the same issue - my Kenmore 790 Gas range makes a humming noise when I am using it to cook; seems like its a common problem yet I haven't seen any causes/solutions. Any thoughts would be really appreciated...thanks.
