planemad1
#1 Posted : Thursday, January 13, 2011 1:40:57 PM(UTC)
planemad1
I have a Frigidaire Dishwasher that wont heat water. I replaced heating element and still not heating. Any ideas on what activates the element or my next step. Thanks in advance for your help.
#2 Posted : Friday, January 14, 2011 2:29:21 AM(UTC)
Could not find info on an FC2 the following are for a FC0. It should be the same.
Replacement parts for FRIGIDAIRE FDB4315LFC0 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the wiring diagram/tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154580201en.pdf
The control board activates the heater.
Unplug/remove power from the unit.
Remove one wire from the hi-limit thermostat.
Measure it with a meter.
Should be 0 ohms.
I would also do the same with the heating element.
It should be 15 to 20 ohms.
It is also a good idea to also check the heater and hi-limit thermostat combo at the control board plug just to be sure you do not have a wiring problem.
If all OK then odds are that your control board is shot.
planemad1
#3 Posted : Thursday, January 20, 2011 8:59:37 AM(UTC)
planemad1
Thanks for the help. I'll give it a try and hope its not the board $$$.
