what does F22 mean? runs for one minute & shuts off.
Originally Posted by: greatergraces@yahoo.com  what does F22 mean? runs for one minute & shuts off. Greatergraces, I can't find an F22 code for a WP dryer, Are you sure about that fail code ? If you could get us a proper model number, we'd be more helpful, and can assist you better. Thanks, :) :) :)
:o ) yes does flash F-22 read at the bottem of page [ quote=Joe / APP Team;332503]Greatergraces,
Thanks,
:) :) :)[/quote Model # is WED6200SW1 Dryer does come on using any temperature settings but shuts off after 1 minute then Flashes F-22 .On temperature setting air only dryer does operate through time setting but the temperature stays extremely hot. thank you for your help we appreciate.
Originally Posted by: greatergraces@yahoo.com  Originally Posted by: Joe / APP Team  Greatergraces,
Thanks,
:) :) :)[/quote Model # is WED6200SW1 Dryer does come on using any temperature settings but shuts off after 1 minute then Flashes F-22 .On temperature setting air only dryer does operate through time setting but the temperature stays extremely hot. thank you for your help we appreciate. Greatgraces, Thanks, Of course you're correct, your dryer does have a F22 code. That code indicates that the Exhaust thermistor resistance is out of specified range, You added something, On timed dry, air dry setting(no heat), the dryer gets extremely hot ? Is that correct ? I was hoping you just had a clogged vent or bad thermistor, but with that information, we've got another problem, shorted element, shorted wires, bad control board, You should get a multi meter, so you can check resistances and circuits, or disconnect the exhaust venting from the back of the dryer and run it on air dry, then a heat cycle and varify, that there's heat in the air dry(no heat) setting. We'll keep an eye out for your response, Good Luck, :) :) :)
:o HELP yes said F-22 read at the bootom of page Originally Posted by: Joe / APP Team  Greatergraces,
Thanks,
greatergrace already have dissconnected exhaust & air dryer is very hot,we already put part that we order on .
Originally Posted by: greatergraces@yahoo.com  greatergrace already have dissconnected exhaust & air dryer is very hot,we already put part that we order on . Greatergraces, So much for the easy stuff, I was not aware you replaced a part, what part did you replace ? Now, You'll need to access the rear of the dryer, remove the back panel, 1. Unplug dryer or disconnect power. 2. Remove the rear panel 3. To remove the thermal cutoff (TCO) a) Remove the two wires from the TCO terminals. b) Remove the hex-head screw, unhook the end of the bracket, and remove the TCO. 4. To remove the heater and inlet thermistor/ high-limit thermostat a) Lift the locking tab and remove the 2-wire connector from the inlet thermistor. b) Remove the wire connector from the high-limit thermostat terminal. c) Remove the two wire connectors from the heater terminal block.Check for a resistance reading from each terminal to the flue box/housing. any resistance would indicate a shorted element and you'd need to replace the heater assembly.d) Remove the two hex-head screws from the heater assembly and remove the assembly.e) Using a flat-blade screwdriver, pry the inlet thermistor terminal off the heater terminal, and remove the thermistor from the assembly.Part number: AP3094254
The next step would be, to access the main control board, 1. Unplug dryer or disconnect power. 2. Turn off gas supply to dryer. 3. Remove the two mounting screws from the rear of the console. 4. Lift the console off the cabinet and position it off to the side.
To remove the machine control: a) Disconnect the machine control board connectors at P8, P9, P13, and P14, then pull the red and black wires off the heater relay terminals. NOTE: On dual element models, also disconnect the violet and black wires from the second heater relay terminals. Once you've removed the wires from the heater relay, with a multi meter, there should be no resistance across the two terminals on the relay, if there is, the relay is stuck closed, and causing the element to be on in all settings, and you'll need a machine control board. Part number: AP4359310
I'm pretty sure you'll find your problem in one of these areas,
or the wiring to one or the other.
Good Luck,
