My top oven won't heat up after self cleaning, what should I do?
A model number may help others help you.
Many units have a thermal cut-off on the back of the oven that can blow shutting down the elements. |
THIS FORUM IS DEAD!!!!!!! |
Frigidaire does not have a thermal fuse in the back. Make sure you try the bake and the broil element to see if they work. If not most likely a clock control. But a model # would be great to verify. Tom ApplianceEducator.com
Here is a manual for a Frigidaire manual. http://frigidaireservicetips.com/pdfs/481_18.pdfIt does have a safety thermostat (see page 37). Please post your model number and then with luck we will be able to find a wiring diagram for your model and hopefully narrow down the possible causes of your problem. |
The model number is PLEB30T9FCC.
Thanks sooo much!:)
Look foward to hearing back....
Here are your parts. Could not find a CC following is CB but should be a real close match. Replacement parts for FRIGIDAIRE PLEB30T9FCB Frigidaire/walloven | AppliancePartsPros.comHere is a wiring diagram http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318046123.pdfIn the wiring diagram it shows the cut-outs in the common wire to the elements so it will kill both elements. If you look at the parts (Item 119 in sections 2 and 3) you will see the thermal cut-outs. If you click on the parts picture, you will get a better view of it. It looks like it is re-settable re: the square red center is probably a pop up. Since getting at is a pain I would check at the relay board. Bake or Broil to DLB connectors should read 10 to 20 ohms. If both readings are open (infinite ohms), you know the thermal cutoff has tripped or a wire has burned out. Be sure to remove power from the unit when working on it!!! You may also want to check the temperature probe, just in case it caused an over heating. Here is a good link on how to do that. http://www.applianceaid.com/elecrange.htmlThe control board also could have caused it to overheat. I am not sure if the cooling fan comes on during self clean. If it is supposed to then I would also check it. The cutoff is probably going to be a pain to get at, perhaps the following will held http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318201514.pdfI would get a oven thermometer and check that the set and actual oven temperatures are close. Here is the timer guide. It shows how to adjust the temperature. See page 18. If this is/was a problem you probably would have seen that the oven always seemed hot and it baked faster than the recipes said. http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318200138.pdfAnd one last thing if everything looks OK and you were using a long self clean cycle. I would clean the oven more often using a shorter self clean. |
