SherryLynn
#1 Posted : Wednesday, January 12, 2011 2:09:11 PM(UTC)
SherryLynn
I have a Duet front load washer the Fdl code is displayed.I istalled a new door switch/lock until and code is still there.:confused:
Joe / APP Team
#2 Posted : Wednesday, January 12, 2011 4:13:16 PM(UTC)
Joe / APP Team
Sherry,
A couple of things you should check,
Make sure the strike(pin) on the door is not loose or broken.
Check the door and door hinges for tight and properly aligned to front panel.
In some cases you have to reset the control, by running the "Diagnostic Test" mode.
The washer must be empty and control must be in the Off state,
Close the door
Turn control on(if button present)
Select the Drain/Spin Cycle
Select No Spin by pressing the Spin Speed touchpad
Press the Prewash or Rinse and Hold option four times with in five seconds.
Any registerred fail code(s) will appear), then,
C:00 should appear in the display.
C:08 should appear at the end of the test cycle.
(you may want to write down the fail codes, so we can determine other possible failures/remedies).
In order to advance through the test mode,
Push the Pre wash or Rinse/Hold option button two times
There are eight test in this this program, and they have to be energized and activated to perform the test properly.
This will also check the control board circuits for proper operation, as well.
Good Luck,
SherryLynn
#3 Posted : Wednesday, January 12, 2011 4:57:33 PM(UTC)
SherryLynn
Nothing loose or broken
SherryLynn
#4 Posted : Thursday, January 13, 2011 5:45:21 AM(UTC)
SherryLynn
I sent this last night but I guess it wasn't sent.I checked the door and hinges they r fine.The latch is as well you can hear a noise but the code still showes.I ran the check you asked me to the only thing that showes is C:00 then back to the door lock code after a few minutes
:confused:
Joe / APP Team
#5 Posted : Thursday, January 13, 2011 7:23:47 AM(UTC)
Joe / APP Team
:confused:
Sherry,
Check and make sure, there are no loose connections or wires between the new door latch assembly and the CCU(central control unit).
If that's OK, you'll need the CCU,
Part number: AP3859567
Apparently the control board, is not seeing the door latch closed/locked circuit.
That would be why the test stopped at C:00
You did a great job.
Good Luck,
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool Duet front load washer model WFW8300SW02 (Washer Repair)
by Guest 12/4/2023 8:39:10 AM(UTC)
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Whirlpool Duet NG Dryer gas smell when off and open door (Dryer Repair)
by Guest 5/16/2023 4:02:36 AM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Need wiring diagram for Duet GHW9150PW1 (Washer Repair)
by Conesus 12/14/2022 10:50:49 AM(UTC)
Whirlpool duet clothes washer (Washer Repair)
by DThiessen 9/28/2022 10:08:52 AM(UTC)
Whirlpool Duet YWED7500VW2 (Dryer Repair)
by Guest 6/14/2022 11:19:46 AM(UTC)
Whirlpool Duet intermittent spinning (Dryer Repair)
by wadeburt 5/17/2022 6:31:21 AM(UTC)
Duet dryer moister sensor (Washer Repair)
by Guest 4/29/2022 10:56:57 AM(UTC)
Whirlpoool Duet not spinning clothes dry (Washer Repair)
by AdamsBT1 4/9/2022 6:03:49 AM(UTC)
