swt1221
#1 Posted : 15 years ago
swt1221
The oven does not work. The clock/timer control board does not work. I can not set baking time and settings for the oven. There is an error code PF on display. Please help me. Thank you.:)
#2 Posted : 15 years ago
Most likely the problem is a bad control board (aka a clock/timer). You have to order the new overlay as well because it's glued to the clock/timer.
- The clock/timer Part number: AP3773897
- The overlay Part number: AP3773935
swt1221
#3 Posted : 15 years ago
swt1221
Thanks Gene for your reply! I really appreciate it. In terms of installing the new parts, is it relatively easy to replace them? Would I need a manual or some special instructions, because I don't know how to replace them. Thanks again.
#4 Posted : 15 years ago
You can easy access the clock by removing the rear control panel cover. Do not forget to turn the power off.
swt1221
#5 Posted : 14 years ago
swt1221
Gene, thanks for answering my questions. It's been 7 months and I still haven't order the parts for replacement yet. I will be doing that later on this month. Thank you very much! =)
#6 Posted : 14 years ago
Happy Holidays!
swt1221
#7 Posted : 14 years ago
swt1221
The repair was successful today! Yay!
#8 Posted : 14 years ago
I'm glad you were able to fix it. Good job!
Thank you for the feedback.
Kenmore Range oven not working (Oven Repair (including Ranges and Cooktops))
by donnalee 13 years ago
