AndrewRuffino
#1 Posted : Tuesday, January 11, 2011 9:25:37 AM(UTC)
AndrewRuffino
When turning right burner on to low, heating element will turn on to high. I have tried to adjust knob from low to high and it continues to be on high temperature. Will I have to replace entire range or a switch? Thanks Andrew Ruffino.
#2 Posted : Wednesday, January 12, 2011 12:50:55 AM(UTC)
Replacement parts for KENMORE 1034348210 | AppliancePartsPros.com
You probably only need a new switch. Third item in the parts list.
Be sure to have the parts people check that this is the correct switch for that element.
Be sure to remove power from the unit when replacing the switch.
Guest (4)
