HelplessHO
#1 Posted : Monday, January 10, 2011 10:35:45 AM(UTC)
HelplessHO
Our water dispenser is not working but the ice dispenser does. I had the water inlet valve checked and the water disperser side is working. I was adviced that it could be the water dispenser control panel that's not working. I need to open the water dispenser front panel but I couldn't figure out how without breaking it. Can you help me? thanks
#2 Posted : Monday, January 10, 2011 1:16:38 PM(UTC)
How old is the water filter? If it's more than a year old then it can be the cause of the problem.
The disassembly instructions are attached to the reply.
- The water filter Part number: AP3182816
File Attachment(s):
Ice and water dispenser.doc (435kb) downloaded 10 time(s).
HelplessHO
#3 Posted : Monday, January 10, 2011 9:59:29 PM(UTC)
HelplessHO
Water filter is less than a yr old. If water filter is the problem then there won't be any water in the ice maker, am I right?
How do you do step no. 3 "Unsnap front cover at bottom of the housing"
#4 Posted : Tuesday, January 11, 2011 12:28:32 PM(UTC)
Originally Posted by: HelplessHO Go to Quoted Post
...How do you do step no. 3 "Unsnap front cover at bottom of the housing"...
It is shown on the picture bellow this instruction.
Guest (4)
Repairing Water Dispenser on Front (Refrigerator & Freezer Repair)
by KAGAR59 3/14/2012 6:58:23 AM(UTC)
