badassbob
#1 Posted : 14 years ago
badassbob
I have a Kenmore range, and the other day the oven stopped working.
The oven heat element appears to be in good condition, but not heat when turned on. When we start the oven you can hear a clicking (not constant, but from time to time - as if it's trying to turn on the element), but not heat.
Everything else about the range works fine (range burners, clock, timer, etc)
Any idea's what make the oven die?
Thanks!
Bob
badassbob
#2 Posted : 14 years ago
badassbob
I wanted to add a couple more things to this to help narrow down the problem.
I just tried to broiler, and it does not work either.
No error codes are being displayed.
It there a way to check for error codes, or do they just display if there is one?
So the oven & broiler do not have heat. Everything else works fine. Any Idea's.
Thanks!
Bob
#3 Posted : 14 years ago
If the unit comes ready it could be that the sensor is no good and the unit thinks it is already up to temperature.
In any case I would check it.
Next I would remove the back and check that a wire from the clock/timer to the elements has not burned off.
Be sure to unplug/remove power from the unit while working on it.
If both the above are OK then odds are that your clock/timer is toast.
Part number: AP3960228
Click on the picture for more info.
Below is a good link with basic info on stove troubleshooting.
http://www.applianceaid.com/erange.html
badassbob
#4 Posted : 14 years ago
badassbob
Thank You. In regards to the senor what is the best way to check this. When I turn on the oven or broiler it does not beep (like when it reaches the specified tempurature). Do I just check the wiring.
I will take the back off now, and inspect the wiring from the clock/timer to the elements.
Thanks!
Bob
#5 Posted : 14 years ago
Odds are it is not the sensor but I would still check it.
Best is to disconnect it at the control board and measure it with a meter.
See the link I added.
badassbob
#6 Posted : 14 years ago
badassbob
I have inspected the wiring. Nothing looks damaged or burnt. All the wiring looks to be in good order. If the temp sensor was bad would the wiring be damaged, or is it possible that the senor can just die?
badassbob
#7 Posted : 14 years ago
badassbob
Thanks! I do have a meter, and will try this now.
badassbob
#8 Posted : 14 years ago
badassbob
Hi. I tried the OHM test on the broiler element, oven element, and the temp sensor.
The broiler & heating element seems to be fine. When I test the OHMs on the elements my digital meters ticks down to 0.00. I believe that mean all is fine.
The temp sensor does move a little, but does not actuall go to zero. Is this normal, or does this indicate a problem.
Thanks!
Bob
#9 Posted : 14 years ago
Sounds like something goofy is going on with your meter.
Almost sounds like you were on a voltage scale.
If you set the mete r to the 200 ohm scale you should get a good solid reading around 20 ohms for each element
For the sensor use the 2,000 ohm scale.
Short the meter leads together before starting so you know the meter is reading OK and if there is a zero offset.
