Hi all..
I have the same problem as Jayvee where my freezer and fresh food are not keeping cold temperature. The refrigerator seems to be cooling..but not enough...my serial number is HF428345....I don't know if this is still under warranty. From Javee's problem, it seems to be the main board. I looked up the part numbers from GE website and it seems to be WR49X10152, the main board. Is this correct? For Javee's refrigerator it seems to have two parts even though its the same model number. WR55X10552 vs. WR49X10152 as in the GE website.
Thanks for any input...
ic3nin39
Could you please just post the problem you are having and I can help you. I don't know where jayvee's post is.
I found jayvee's thread, if indeed you are having the same symptoms, you need part# WR49x10152. This board is for the dual evaperator model refrigerators, the other part# is for the single evap models. It is very important to follow the directions that come with the board.
