liz777
#1 Posted : Thursday, January 6, 2011 9:11:35 PM(UTC)
liz777
My dryer turns on and runs but does not heat up on any setting. Thermostat, element, fuse, wiring? Easiest and cheapest way to find out which needs to be replaced?
kayakcrzy
#2 Posted : Friday, January 7, 2011 4:01:45 AM(UTC)
kayakcrzy
You need to check all those parts, you just mentioned, with an ohm meter. It has to be one of the three you mentioned. Tom ApplianceEducator.com
#3 Posted : Friday, January 7, 2011 4:05:18 AM(UTC)
Replacement parts for WHIRLPOOL YREX5634PQ0 29`` ELECTRIC DRYER | AppliancePartsPros.com
The first thing to check is the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Once you know that the power is good then you can check the heating coil and thermostats with the unit unplugged using resistance on the meter.
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 12/13/2011 5:11:32 PM(UTC)
by kamputty 4/11/2010 8:40:39 PM(UTC)
by pauleouellette 3/10/2009 12:37:59 PM(UTC)
by bseibes 8/28/2008 6:59:14 PM(UTC)
dryer does not heat up (Dryer Repair)
by tkeemm 2/27/2008 6:37:29 AM(UTC)
by dralonso 2/21/2008 10:52:52 AM(UTC)
